This kit has the original lookin Chrysler inner seals. See how they're rubber coated over the metal? I've even seen some original OEM ones that were all rubber. Just real thick rubber.
And the rear end lube does not lubricate the axle bearings!
Dang, i'm going to pull my axles now and recheck for outer seals.Yeah, that could certainly cause a leak. I've never seen people leave the outer ones out. I eckon cause they are RIGHT THERE behind the flange, but I've torn down countless ones that were missing the inner seals. Not tore up. Just not there at all.
Dang, i'm going to pull my axles now and recheck.
I agree it's out of the car anyway.If you have any misgivings about them, it sure wouldn't hurt.
Nice seal puller.OE inner seal... has metal OD..
View attachment 1715722148 View attachment 1715722150
That's just the locator tool... lol.. this is the remover..Nice seal puller.
Exactly what I asked the OP in post #7... still waiting for him to come back..Inner seal, is an oil seal. The outer seal is a Grease seal for the bearings.
.It is the seal closest to the housing behind the bearing. Almost everybody leaves those out.
Outer seal is there also to keep the grease that you pack in the OEM bearings from getting contaminated and from washing out. Reason most people do not know much about them or routinely replace them is because the bearing has to be removed to replace the seal in the retainer..
Well Rusty I learned something from you today.
All these years I never noticed that outer seal.
And I replaced quite a few axle bearings. A lot of them I replace them with the green bearings so I wouldn't have noticed that anyway. But the only reason I can think there would be a seal out there underneath that adjuster or that axle retainer would be just to keep dirt out of getting into the axle bearings. Because the inner seal should keep all the rear end fluid inside the housing.
So a big thumbs up to you Rusty.
