Stop in for a cup of coffee
I had posted a link to the unveiling a while back. 600hp, dual overhead cam, 7.6L, v12, 2 speed transmission, and engine doesn't turn as normal, lower unit gear case steers instead. Very cool
Is that what that was? I remember the first pic, but don't recall seeing any info.
Guys what would you offer on that dakota I posted pics of, needs a brake line, and a water pump that I know of and 120K on it. I am just curious. 1999 not a 2002.
Thanks went 2K just wanted to make sure, cant find a value on a R/T anywhere except perfect.
My arm was really sore day or so after the shots. I think the first one was worse because I went to work right after. Been over a month now and It does get sore occasionally, but it doesn’t last long.
The 5.9L is exclusive to the R/T, which is only available in two-wheel drive with the 6.5-foot box. Yep, the R/T is a narrowly outlined package that requires an automatic overdrive transmission and a 3.91 Sure-Grip rear to spin the 17x9-inch alloy wheels wrapped with beefy 255/55R17 Goodyears. Special wheel-opening flares accent the body. Of course you can choose between a regular cab and an extended Club Cab, and select from a slender palette of colors: Flame Red, Black, Intense Blue, or Deep Amethyst. But we're not complaining. The brawny Dodge is designed more for street performance than for hauling loads, as evidenced by a ride height 2 inches lower than the standard truck, the 21mm rear sway bar, and that fat performance rubber
So instead Mercury chose to introduce the engine via video released on Facebook, followed by the product details going live on Mercury's Facebook page. Retail pricing is said to be "in the $77,000 range."
Are they kidding?????????? ****!
Damn! My house wasn't much more than that!
And they show boats running 4 of them...
Second covid shot today, then planting fruit trees and blueberry bushes, ought to be interesting lol! Better try to get that done today.
Good luck! The way my arm hurt next day when I worked right after shot one, I did nothing after shot 2.
