I bought a BBD from a member here, now I want to put a kit in it. Tag says 8187s, I was trying to find a reference of what is was on so I can look at jet and meter rod sizes to see if close for my 198. Thanks!
No, 3500# means truck, not car.
Is there any corralation between bbd jet number and size.
310 vs 301 vs 294 etc
In That linked post with The Carter sheets actual part number is 120-386 and next to that Is .086 120-383 would be .083. Edelbrock Jets will fit
1974 BBD carburetors and up used a simple correlation system between jet numbers and size,as shown in above post. The 1973 and older BBD carbs used a different system regarding jet numbers and size. Maybe Bugman can give a more thorough explanation.
