Stop in for a cup of coffee
Gas? Gas? I need gas. Went to get the Harley out but the battery was to low to get it to start. No problem put it on the charger....get it rumbling and look and no gas. I usually fill them up if they are sitting so it went somewhere. Grab the can and it's empty. Yep I need gas.
Why do I see someone running around the house pulling his hair out and looking in every building for gas cans, now running with a George credit card :rofl::rofl::rofl:
What do they use for windows? Plexi, Lexan or glass? Guessing not Lexan as that would be really expensive...
Not lexon, and not plexy glass, they called it something else, stringer and will not yellow or dull..I will see and get back, but it's much harder
Interesting. So it is a plastic and not glass?
I considered making a small greenhouse. The windows are the biggest cost. I have a bunch of big display frames that I assume are plexi. Maybe I will set a piece out back for the summer and see what it does...
I should know this stuff, cause we make a lot of clear guards for the pressroom. Plexi is an acrylic and Lexan is polycarbonat. We use mostly the later because it is mor impact resistant. But a quick internet search suggests that plexi is most used in greenhouses. One site said use the doubled thermopane safety glass! $$$$
Yep, left side is stopping. Right side, not so much. And most brake power in front. So, if nothing is dragging with brake off, right front is likely not working. Could just need bled.
Check your fluid level. Maybe a leaky wheel cylinder. Ask me how I know.
Try Mike's Chili. :lol:
I did the same but still had one leak. Can't trust new. If your front shoe got fluid on it say on the right front, the car will pull left. Top it off as some missing?
Hey guys, have you ever seen solder in battery cable clamps? Let's see, a 2 piece mold and some melted lead tire weights. Cut the cable , strip the end, and solder it in. How many factory battery cables were replaced or "fixed" with one of those bolt on repair ends. :BangHead: :BangHead:
