[SOLD] SBP Kelsey Hayes Disc Brakes
65 Dartman
1 of None 65 Dart Sedan Delivery
Strasburg, VA
Got a set of SBP Kelsey Hayes disc brakes that came off a friend's running, driving car (64 Dart). Included is the spindles, calipers, rotors and dust shields - everything pictured. This should fit from 63 through 72 when using the small ball joint UCA. If disassembled into component parts, they ought to fit in a large flat rate box - about $15 per box to anywhere there's a US ZIP Code. Otherwise actually shipping from 22657. Asking $400 plus the ride. Also got a set of 73-76 discs in another thread.
Nobody needs a set of KH disc brakes 5 on 4 SBP ready to bolt on, bleed and go? I'm surprised!
I tried to fit one of these bolted together assemblies in a large flat rate box and it just wasn't gonna go :(. I have 2 complete KH disc set-ups (but all separated) for other projects and and looks like the rotors & dust shields will go in one large flat rate box and the calipers, spindles & hardware in another :-D: So looks like shipping will be $29 to any ZIP Code
How much meat is left on the rotors. What size are the rotors. Do you know when the calipers were rebuilt. Thanks
What I am selling I bought from a friend who removed them from his 64 Dart when he decided to go LBP. I know he had the calipers rebuilt so I will have to check with him on that. I will have to take the rotors to a machine shop as I have no way of measuring the thickness other than visually comparing them to the NOS rotors I have.
I do have 2 sets of rebuilt calipers (as well as the NOS rotors) and they will be used on my Barracuda and Valiant vert.
