Removing Rear Seat and rear door panels
-Sledgehammer-
Mopar Performance
Central, PA
how the heck do you remove the rear seat with a cage and also the rear door panels... do the upper part of the rear door thats painted come out also with vinyl! (71 dart)
so frustrated right now! :angryfir:
Well I might be able to help with the rear seat issue...my '68 fish you have to push the bottom seat towards the back of the car and lift up. 2 L shaped brackets underneath it.
It frustrated the hell out of me too, ended up having to call a friend to figure it out.
on my 74 the upper plastic trim piece is seperate from the door panel. i have to remove the door panel first after removing the window handle, armrest, etc. then the panel pulls loose , its being held by the clips but it also tucks up under the plastic trim piece about 1/8 ". then you will see the screws holding the top trim piece. i would think a 71 is about the same.
