69 Dodge dart street/strip car
Indy dart
Rating - 0%
0   0   0
69 Dodge Dart. Original 6 cylinder car. Professional mini tub, ford 9 inch, Auburn Posi, Richmond gears, Moser axles. 3:89 ratio. I bought an Indy 470ci crate engine for $9700 for the car. It produces 610 hp on pump gas. I have the dyno sheet and build sheet for the engine. The car has a built 727 3 speed transmission with standard pattern valve body and comes with transmission blanket. Car has complete stock interior with 2 five point harnesses. Disc Brakes all the way around the car. This car has a AlterKations front end with QA1 coil overs.
We have driven it roughly 200 miles in 3 years. We have taken it to the track 2 times and ran a 11.00. We recently installed a nitrous kit and sprayed the car 1 time with just a 100 shot.
Frame has been tied
Cal traces with split mono leaf springs
Billet specialties street lite wheels
m/t drag radials and bf goodrich 295/50/15 tires
Professional cage built to run as quick as 9.99
20 gallon fuel cell with Big End fuel pump and regulator
aluminum radiator and twin electric fan
Aluminum drive shaft. with driveshaft loops
Located in Bolivar, MO. Asking 15000 OBO
Pictures are here: http://springfield.craigslist.org/cto/3286527822.html
Is this car still available? The craigslist ad is no longer up to view the pictures of the car.
