6pakattack
OK,tired of my gas prices already !!! Are there varying head gasket thicknesses that I could try to drop CR,or is it time to just do yet another head ?:violent1:
Any idea what a stock head typically cc's at?
1st,I CAN't run 91, 100 is the lowest I've used,and that's still backing timing out ! Compression is 11:1 ! No I can't give you all the teckno terms, butI have a reliable builder that I trust ! The Head was built by an A Body member and shipped to me, so I don't know exactly what race tricks he put into it ! I do have the original stock head that I shaved .090 off of and had the bowls blended that I was tempted to put together and try that and see how I made out ! Camshaft is 530/278 (?), I'd have to dig a bit ! CRS sucks !!!
It was not built to be timid !!
ops:Is the dizzy regraphed and is it HEI ???
ops:
for 11.00 t0 1, you should be running an alum. head., that`s too high for a cast head, not that it won`t work, it just won`t do it w/o running higher octane gas. you can typically run a point higher w/ alum.-just sayin---bob
Cometic makes slant 6 head gaskets?
Cometic does not make an MLS head gasket for a /6 at this time.
ops:
You're right,it WILL run all day with the right octane gas ! It would probably be a little happier with better than 100 Octane too !! But, I won't be needing to worry about it any more !
Sounds like problem solved. Next time think of adding water injection.
