Snake
Mopar Nut
IF i May ASK what your thoughts are on the holley 8-81670 I just ordered it hope i have not made an mistake.
I figured by the title of this thread that it was you SSssssnake....
If it is a vacuum secondary, I would recommend buying the secondary spring kit and install the lighter yellow spring for the vacuum secondaries. This will let it open sooner and be fully open by 6000 RPM. The lighter yellow spring is the shorter one. There are two yellow springs in the kit, and the longer one is just one step behind the short yellow one.
Glad to here it scores well.:burnout:
My recommendation would be to try it out just as it is out of the box. I would not take it apart and change anything. Maybe I got blue eyes, but I actually believe that when I buy something I get it as described. As you seen from my own thread I have just installed the same carb, not plugging Holley here. I hope to get it as described from any manufacture, or private add.
I had to make it a little richer on the idle mixture screws to get it to idle as I want though.
I hope you will be happy with It Snake!
well we will find out in 3 weeks and then in the spring to test it out on the road.:burnout::burnout::burnout::burnout:
You are going to have your car out in 3 weeks !!!!!We were hit bya storm on Friday and another one is coming in tonight..this is friggin' weird..I envy you..
If you tune it so you can feel the secondaries open, you have put too light a spring in it. If you can feel the transition, the car will be slower than if it has a smooth transition into the secondary side.
Just did some reading on that 670 and saw a video thay have a big time problim with off idle bog anyone care to add,i am thinking of of anouther carb.Help.I just cant make of my mind nowadays lol.
Snake, make a choice and give it a chance. :banghead:
Get the new carb, give it a try. If you don't like the way it runs, post up for tune up tips. Try to make it work first, before you second guess yourself and keep changing directions.
Like in the first Karate Kid. "You must stick with your decision. If you change your mind in middle of the street.... You get squashed like grape...."
Give the new carb a chance. If it doesn't work out, you can always change it again later. Don't always be afraid of change, sometimes change is good.
If you don't try something new, how is it going to run any better? Don't change your mind until you've had a chance to try it. What if that was the fix and you missed it?
Have patience Grasshopper.... :-D
