Hopefully the picture below explains it all. But what could I call this specific connector or where could I find one?
http://i.imgur.com/f9e9NC4.jpg
Basically, I had a wire burn through the insulation and nearly start a fire. I cut the old part out and put in new 14ga. It's the main lead off the alternator. Then, soon as I tried to jump the battery, the picture above went up in smoke and the insulation just crumbled off. So at the this point, I'm not sure if I have a short somewhere which is causing the wires to get way hotter than they should be or if the wires just broke down over time and can't handle the voltage anymore. Last month, I did replace the alternator with a new 60amp. I have no idea what the old one was, I couldn't make out any markings on it.
The wire burnt beyond the fusible link, which seems like that wire didn't do its job properly if I understand it was suppose to break before this happens. And some of the wires are somewhat fused into the connector so I plan to just replace that entire piece (and most like likely all the wires in the engine bay).
I've unfortunately have had to rely on this car as my daily driver the past few weeks but will hopefully have my chrysler back by this weekend. But it looks like I may be taking the bus for a few days
I won't even get into the neutral safety switch/connector that I found shredded and dangling under my car friday...
Actually, I think I found it.
http://www.classicindustries.com/product/mopar/parts/md4501.html
Even though it says it's only for up to '69, it looks identical to mine.
