[SOLD] 1973 Dart Sedan, $1000, SW Ohio
1972Swinger
None
Rating - 50%
1   1   0
Selling my 1973 four-door Dart.
Motor is a '72 225. Auto transmission on the column. Brand new fuel tank, sending unit, tank pad, filler seal, and trunk floor boot. Fresh oil change, new coolant. New poly motor mounts. Slot mag wheels. Including new upper and lower MOOG ball joints. Big bolt pattern with front disc brakes. Power steering and power brakes. Electronic ignition.
Purchased this as a project. Swapped in a new slant six to replace one that was blown up. There is some electrical gremlin that I can't diagnose. Voltage drop inside will not let the key turn the motor over. Can jump the relay under the hood and it cranks fine. I have not had it running, but the motor did run when pulled from parts car.
I don't have the time or space to keep chasing the problem. Harvest time is coming up and I need it out of the shop. Body is in decent shape. Floors are good, lower quarter panels were replaced by a previous owner and don't paint match. Vinyl roof is peeling at the back trim. Interior needs headliner and seat reupholstered.
$1,000 CASH gets it. Hate to sell it, was looking forward to driving it, but it has aggrevated me for the last time. Clean Ohio title.
Located 30 miles east of Cincinnati.
Requested pictures for Crossrammed340.
Engine picture as requested.
