[SOLD] 408 build parts sale ALL PARTS NEW
ocrj
Orange County
Have been in the process of acquiring parts over the past 6 months to build a really nice 408, but a sudden family medical emergency has forced me to abandon the build.
Here is a list of parts and part#
All items are brand new
Edelbrock Aluminum Bare Heads EDL-60769 &
Moroso perm-align valve cover gaskets with ARP valve cover studs/hardware - SOLD pending payment
Balanced Scat Engine Rotating Assemblies 1-48035BI - $1575
Forged Crank/Forged Dish Pistons/File fit rings/I beam
Edelbrock Rpm Air Gap Intake Manifold 7576 - SOLD
Felpro gaskets/ARP 12pt Manifold Bolts/ARP Carb studs/Mancini racing billet aluminum water neck/milodon 180 high flow thermostat included
AED Ultra HO-Series Carburetors U750HO-BK - $550
AED hard feed line & throttle bracket assembly included
Howards Cams Street Series Retrofit Hydraulic Roller Lifters 91764 - SOLD
Howards Cams Retrofit Hydraulic Roller Camshafts 712105-10 - $275
288/294, Lift .530/.530
MSD Package - SOLD
MSD Billet Distributors 8534,
MSD Blaster SS Coils 8207,
MSD 6AL-2 Ignition Boxes 6421,
MSD 8.5mm Super Conductor Spark Plug Wire Sets 31189,
MSD Pro-Clamp Wire Separators 8843
8 - MSD Iridium Spark Plugs 3731
Summit Racing® Spark Plug Boot Protectors SUM-350119BLK
Moroso Street/Strip Oil Pans 20730 & Moroso Oil Pump Pickups 24700 - SOLD
Edelbrock Victor Series Mechanical Water Pumps 8877 - $175
Cloyes Billet Steel Timing Sets 9-3603X9 & Cloyes Replacement Timing Chain Tensioners 9-5387 - SOLD
ATI Standard Harmonic Balancers 917400E - SOLD
Precision Oil Pumps Blueprinted Melling SB Mopar High Volume Pump & SB Mopar Billet HD Oil Pump Driveshaft - SOLD
Hughes Engines
7382K Main Stud Girdle Kit - SOLD
All parts are located in Orange County, CA and are available for local pickup
Prices included shipping to the lower 48
Here is some info I found on the Jegs site.
http://www.jegs.com/i/Scat/942/1-48035BI/10002/-1
Scat#942-1-48035BI
Chrysler 360 4340 Forged Competition Rotating Assembly•408ci
•4.030'' Bore
•Forged Dish Piston
•10.2:1 w/62cc; 9.7:1 w/68cc; 9.3:1 w/70cc
•4.000'' Crank Stroke
•6.123'' Rod Length
•Internal Balanced Assembly
