B body Well-Known Member Joined Jan 22, 2011 Messages 59 Reaction score 16 Location wisconsin Jan 20, 2016 #1 Any retro roller hyd lifters that drop in with rpm aluminum heads still on That work without grinding ?
clv22p 72 Dodge Demon 340 Joined Feb 2, 2012 Messages 301 Reaction score 53 Location Nashville, Tennessee Jan 20, 2016 #2 Mrl
70aarcuda Master Hoader of SBM Legendary Member Joined Jan 16, 2005 Messages 16,639 Reaction score 5,965 Location las vegas Jan 20, 2016 #3 with the heads still on?
1970Duster Well-Known Member Joined May 30, 2010 Messages 6,644 Reaction score 215 Jan 21, 2016 #4 No. You need to open up the Pushrod holes in order to use hyd roller lifters.
DartVadar Well-Known Member Joined Apr 3, 2013 Messages 1,293 Reaction score 39 Location Alberta Jan 21, 2016 #5 Get MRL lifters, Im running the solid rollers in my 360. Dropped in and fit perfectly. But you have to have the heads off to install them. I dont think there are any retrofit lifters that you can install with the heads on.
