[SOLD] A-Body 8 3/4 Housing and 742 Case
3404spdDuster
Racine,Wi
I have forsale my a-body 8 3/4 housing i was going to use but going a different route..housing is already in primer..i can paint it for extra..
Also comes with a 742 case with 3.23..non posi and powder coated pinion snubber.
Also have small bolt pattern axles with adapter to large bolt pattern for 100$
Want to sell the housing and 3rd member as a package..
Asking 500$
Will not ship..but will meet a reasonable distance if serious.
Located in SE/WI
Do you still have the 8-3/4 SBP axles? Will the adapters cone off or are they permanently attached? Would you be intersted in shipping the axles? How much for the axles to zip code 21206? Thank you for your time.
Frank
