Still a slight arc at plug after changing them?
challenger57
cuda57
york, pa.
I had an arc at all my plugs in my 360 with autolite 64's. I changed them out today to NGK 2023's. At idle it still exist but not always like before. It actually looks like a ring around the plug. Can't tell if it is around the porcelain or at the thread. What are some thoughts and sollutions? The accel yellow wires are at least 10 yrs old. What about using dielectric grease around the threads?
I would be checking for opens, like open coil / plug wires, or maybe what has become known as "rotor phasing" problems. The number one thing would be very high that is abnormal high voltage in the secondary circuit.
I wonder if the spark plug boots are carbon tracked? I had that arcing problem back in the '80s with Champion plugs been running autolites since and no problems. Sometimes when you have arcing and just change the spark plugs the spark plug boots are carbon tracked providing a path for the electric to travel down. Only way out is to replace spark plug wires and spark plugs both at the same time.
Are all the wires doing it? Then I would put new wires on it. If just one, I would swap it to another location. If the halo follows the wire,I would replace it. If the halo stays with the plug, pull it and check the gap. Large gaps require extra voltage to initiate the spark. The coil usually has the reserve. The wire sometimes not.The big fat square Accell SuperCoil seems to fire any typical gap. Mine has been firing the same Champions for 10 or more years.The original gap was .045. At 100,000 miles later, I have no idea what the gaps might be. Still starts click/vroom.Still hits 7200. Probably still goes 93/eighth
Only saints should have halos, and only in pictures.
I wonder if the spark plug boots are carbon tracked? .
Good point. Some sort of dirt / contamination could have made the boot / wire conduct. I've run some plugs WITHOUT a boot, the boot got torn, or burned, or too close to a header, ran without. They should not arc
I like the concept of the carbon track of the plug wires. I know they are over 10 yrs old, that is how long I have had the car. I guess I will add them to my summit order.
