[SOLD] Disc Brake Conversion Kit (A-Body)
Convert4Speed
Colorado
Disc brake conversion kit from Scarebird Brake LLC for 1960-72 Dodge, Plymouth "A" body, with 9" drums Wheel Kit. Take a look at the manufacturers description at: 1960-72 Dodge, Plymouth "A" body, with 9" drums Wheel Kit
I have the backing plates, rotors, calipers with extra pads, hoses, and pressure valve. A picture and the installation instructions are attached.
Parts are located in 80401 zip code. $220 plus shipping.
  • DiscBrakes01.pdf
Parts are located in 80401 zip code. $220 plus shipping.View attachment 1714964635
PM sent
I really don't know much about these components. The guy I bought the car from planned to install them, but he rebuilt the stock brakes and the car is is really good condition, so I have them with no intention of installing them. Take a look at the link to the manufacturers description, and read the attached instructions. It looks to me like the rotors will need to be drilled to the 4" or 5" pattern, your choice.
Ok I see do you know if you have all the pieces to the kit? if your willing to wait till Tuesday I can do paypal shipped to 32536
What I have is pictured: 2 backing plates, 2 rotors, 2 calipers, 2 hoses, 1 pressure valve or regulator, some mounting bolts (pictured), mounting studs and nuts (more than what's picture), and that's about it. I also have a new or re-manufactured master cylinder that I would sell for $40 additional.
