dodgedude
I have a nice used sure grip set up. The pinion yoke has been changed to a good used one with factory straps and bolts, rather than what is pictured. New pinion seal installed. This should be a drop in and go. I did not take it fully apart to inspect, but worked fine when removed. I went with a 3.91 spool set up for the strip.
$500 shipped to you in lower 48. $450 picked up in Central KS. If you want it shipped elsewhere, 100% of the freight charges are on you above the first $50.
