[FOR SALE] 408ci 360 stroker with 904, radiator, headers and exhaust
aaronj
Active Member
raeford
Rating - 0%
0   0   0
I have a very low mile 360 stroker-complete to included: 904 trans, a body radiator, headers, exhaust, a body drive shaft, and motor mounts.
Last winter I purchased a very clean 68 valiant that came with this engine. I have all the receipts for the work done to the engine. I purchased the car with the plan to swap over to a big block that I had sitting on the stand. Well the swap is done and I was planing on keeping this little guy for a future project car. I have since changed my mind. The wife and I are moving and this is one less thing that I want to deal with and I have enough projects to last me for along time!
The engine was built around 2013. The previous owner didn't drive the car much, just to local shows and when the weather was nice. I would guess there are less than 3000 miles on the engine.
Here are some of the engine spec that i have documentation for
-Eagle rotating assembly.
-Comp Cam flat tappet hydraulic (Card Below)
-Comp Cam HE lifters
-Weiand 8007 stealth aluminum intake
-Summit 600 Cfm carb
-Comp cam timing chain
-Summit Brand balancer
-Head casting numbers 2843675
-Block casting number-3870230
Asking 3K
Located in Raeford NC
Idle video from when i bought it.
Any idea how much it would cost to ship to CA 94534?
My 440 was around 600 to ship from WA to NC through YRC
Got any info on the transmission? Stall converter,valve body,etc.....
Im pretty its was rebuilt to stock spec. Ill reengage the guy i bought it from and double check. I can say that it shifted smooth and the trans fluid is nice and clean.
I'm gonna guess because of the price of the kit, that this a CAST Eagle crankshaft?
Ill have to pull the pan to verify.
Hi Aaron, I was wondering if you pulled the pan and checked the crank?
The casting number you provided for the heads says they are 318 heads. Do you have any info from previous owner if larger valves were put in? Any port work done?
By the way, nice looking Valiant!
