Big block port layout
rick4106
louisiana
Does anyone recognize this port layout on this intake. Suppose to be big block mopar.
Time to head to the autoparts store to sift through gaskets!
It's not BOP that I can tell, but I'm no expert. Got a brand on it?
Well there sure aren't many engines that have no coolant passages in the intake, and also don't stick the distributor thru it somewhere. But no that's no stock big block Mopar. Something race-only? Or maybe fits something like an old Cadillac or Oldsmobile? Sure isn't for a Chevy or a Ford either.
After owning 915,452,906,346,stageIV,stageV,Indy sr, and Indy ez. I know it's not a stock layout. Don't know about original B1, or Fred brewer. To small for predator. This is on a Hogans sheet metal single 4 tunnel ram. Going to give them a call tomorrow to see if number on bottom is any help.
Big dummy what size engine. Any dyno numbers
517.....Ran 5.30 in a 2600lb car with the head over ported leaking water!Only Dynoed at the track!One time added 10% nitro and the car was all over the track with a 108 60 ft!
