I would LOVE anti-lock brakes on my 'Cuda.....
Does anyone make a conversion kit or have any of you done a custom conversion?
Jeff
Jeff
Actually, I DO want anti-lock brakes.You don't need nor want ABS. What you WANT is to balance the system so that it stops correctly. The main ingredients are the operating condition of your brake system, whatever changes (conversions) you have done with regard to brake type, size, wheel cylinder size or caliper size and type, AND THE TYPE of brake lining, and the wheels and tires size.
Install an adjustable proportioning valve.
I have just put together a 99 Dakota that I bought "non running" which has 4W ABS. Turns out you need an expensive scan tool (not the dimestore code reader) which programs the module in the truck to "diddle" the solenoids and drive the air out of them.
THAT SYSTEM is coming OUT!!!
Anti lock brakes, have proved to be harmful in some circumstances. So much so, they are OPTIONAL now on some cars, no longer standard equipment.Actually, I DO want anti-lock brakes.
Jeff
I really like them.....I don't see any reason they would be anything but an improvement. ..Anti lock brakes, have proved to be harmful in some circumstances. So much so, they are OPTIONAL now on some cars, no longer standard equipment.
How aboutI really like them.....I don't see any reason they would be anything but an improvement. ..
Jeff
I appreciate the information but I'm not convinced. ....
Just trying to help.I appreciate the information but I'm not convinced. ....
Regardless, does anyone make a conversion kit?
Jeff
Probably could source the needed parts from Pic-a-Parts.I know and thank you!
Jeff
Ontario has a Great Pic-A-Part.Probably could source the needed parts from Pic-a-Parts.
Probably would come to that....Google came up with nothing...Probably could source the needed parts from Pic-a-Parts.
Need help? I could come up....Probably would come to that....Google came up with nothing...
Jeff
I'm still kicking the idea around....but I may take you up on that one day!Need help? I could come up....
