[FOR SALE] 1971 Plymouth Scamp/dart for sale.
GoDartGo
thread killer un-member
Athens Michigan
For Sale, (again) 1971 Plymouth Scamp made over into a Dodge Dart. Original bench seat interior with new carpet. Body 95% rust free. Wiring harness has NEVER been cut into.
no heater or radio.
*1978 360 w/ speed pro 9 to 1 pistons- ported 1992 Magnum heads- headers. Solid motor mounts - 8quart pan- Deep pan 727TF w/ RMVB
B&M Mega shifter, 7290 yoke both ends of drive shaft- 8.75 open pig w/ 3.55 gears and green bearings. Narrowed/braced rear axle with new
leaf springs in 2007, moved 3/4” inboard.
Front end rebuilt in 2010 with Scare Bird disc brakes, new master cylinder/brake lines in 2007. Painted in 2008.
Steel wheels on BF goodrich tires.
I bought a New steering box, also I have a brand new Torque converter , both go with the car.
I’m not gonna give this car away and don’t need to sell. I have other plans in life that don’t include this car.
I’m asking $6200.00 AS IS WHERE IS. I'm located in southern Michigan
The pictures are from when it was cleaned. It gets used a lot in the summer and now is not so clean.
Where is the 5% of rust? How clean is it underneath? Thanks. Looks nice with that color.
There is a quarter size hole in the inner quarter extension and a 5"crack on the lower drivers side quarter.
The rails and the pans are all very solid. In the last ten plus year I've owned the car I have been over every inch, top and bottom. But you might have to see for your self.
I sent you a PM to discuss if you still have the car. Could you let me know when you have the chance? Thanks.
A reminder to those who don't read the ad. I'm asking $6200. If you gotta have it shipped. Then that's on YOU. I will part it out before I sell it below $6200.
EDIT. It is no longer for sale here. Thank you FABO for the free ad.
