[SOLD] Off set super stock front spring bracket and energy suspension bushings
70Roadkill
Dexter
up for sale is a pair of front 3/4” off set front spring hanger brackets and a pair of energy suspension front bushings. These take the 5/8” bolt. Will include a small package of the lube for the bushings.
zip code is from 48130
$65 plus the ride and the 3% fees.
So, if I had these I would not need the rear offset hangers ? I need to see if these will fit my 66 Valiant with 72 Dart springs
The studs pattern is for a body, a body studs are narrower at the top.b and e body are wider at the top from what I’m told. Nover owned b or e body. These are sold pending payment.
