[WANTED] 68 barracuda convertible parts
I have all that stuff! The glass is still in the car, the stainless I have at home, as well as the interior panels. I can pic it later if you need it still!
Eddie,
I have an NOS Left Quarter Glass in Clear. PM me if he's interested. It has the lower hardware attached to it. I also have some used ones, that are driver quality at best not nice.
Martin
Eddie the a pillar plastic trim is the same as the hard top only cut off. If you look on the inside of the hardtop trim you will see a line in it. That is where the convertible trim is cut. If I can find it I use to have pictures of both side by side showing it.
