anyone know where to buy 7-1/4" axles seals
Back in the days when "real" parts counter(people) had REAL paper catalogs we had size charts (Look up the IBI, International Bearing Interchange, they make one for seals too) We could size from C/R, National, Victor and others. Is the problem an application part number or no one stocks them?
SKF
http://www.tristate-bearing.com/pdf/SKF/skf_seal_catalog.pdf
Timken
https://www.basco.com.pe/pdf/timken/timken_seal_specification_guide_us.pdf
Garlock:
http://www.allsealsinc.com/klozure_catalog.pdf
Speedi-sleeve listings
https://www.oit.edu/docs/default-so...ments/speedi-sleeve-size-listing.pdf?sfvrsn=2
good old Rockauto, if anything, they sure can spec some obscure part numbers, but dont trust them fully unless you can verify with a cross reference. Just right click on manufacture part number and do an internet search.
the supposedly "old school" places near me cant source them
No parts books left,way back when stuff was written on paper.
In my supplier’s parts lookup,national 484058. Pricey little buggers....
This is what I just recently installed in My 69 7.25"
Axle seals 2x 5124(484058) 480 S 1.328 2.227 2.233 .0145 .036 .065 $9 <<==== correct
