B3422w5
hi all..... I have a 69 Dart I am swapping over to 904 here in a few days
I have in perfect working order, a 727 with reverse manual valve body, an 8 inch convertor that flashes 4500 behind my 10.4 compression 360 with mildly ported eddies, and a custom built Drive train service driveshaft.
This stuff was all fresh little better than a year ago, and in the car when I bought it then. probably 200 street miles and 6 or 7 outings at the track last summer. haven't been out yet this year.
convertor is a tight 8 inch that works well on the street and the track. car went 11.20's last time out last fall. 119 mph, 1.58 60 foot at 3300 pounds
will sell all of it for first 1000 bucks. wont know till I remove it what make the convertor is,on that I am unsure at this point. Was told its an ATI, but wont know till I verify. it works good, I do know that, whatever it is. trans shifts perfectly and firmly
wont ship, located in South west Michigan
again, first 1000 takes all..... great deal for anyone for car that's a street strip, or strip smallblock.
I am pretty picky about my stuff, these parts all work very nicely, zero issues.
pictures coming when I do the swap
edit...... forgot to note...... driveshaft is 50.5 inches center to center, little longer than stock would be. car has ladder bar rear, I suspect the rear was moved back slightly to center tires when it was built. so it definitely wont be to short for anybody, and can be cut shorter if need be for your application
