jonnyrose Well-Known Member Joined Aug 30, 2017 Messages 227 Reaction score 89 Location canada May 22, 2018 #1 Howdy bought a standard gear steering colum and just getting a standard gear steering box,will i need a different pitman arm or are they the same
Streetsboro Rick FABO Gold Member FABO Gold Member Joined Apr 27, 2018 Messages 187 Reaction score 137 Location Streetsboro Ohio May 22, 2018 #2 You will need to get one for the manual box
limegreen70 Pokorny Enterprise's Joined Apr 27, 2014 Messages 1,902 Reaction score 563 Location Milton PA May 22, 2018 #3 Manual and power Boxes i believe use the same pitman arm. But 73+ Power steering boxes went to a large sector so they use a bigger spline pitman arm. I took the pitman arm off a power steering box and it went on a manual box, i had no problem.
Streetsboro Rick FABO Gold Member FABO Gold Member Joined Apr 27, 2018 Messages 187 Reaction score 137 Location Streetsboro Ohio May 22, 2018 #4 This is true but what year car are we talking about?
1969383S FABO Gold Member FABO Gold Member Joined Jan 8, 2012 Messages 7,098 Reaction score 4,247 May 22, 2018 #5 Streetsboro Rick said: This is true but what year car are we talking about? Click to expand... And what engine?
70aarcuda Master Hoader of SBM Legendary Member Joined Jan 16, 2005 Messages 16,639 Reaction score 5,966 Location las vegas May 22, 2018 #6 When you need the truth........ Steering Box Info
70aarcuda Master Hoader of SBM Legendary Member Joined Jan 16, 2005 Messages 16,639 Reaction score 5,966 Location las vegas May 22, 2018 #7 Moog/Chrysler Suspension Part Numbers Scroll down and you will find the correct Moog part number for what you need.
jonnyrose Well-Known Member Joined Aug 30, 2017 Messages 227 Reaction score 89 Location canada May 23, 2018 #8 1968 2dr post six cylinder k member with 360 v8 with conversion mounts
jonnyrose Well-Known Member Joined Aug 30, 2017 Messages 227 Reaction score 89 Location canada May 23, 2018 #9 looks like the same part number,now i will go and check my power steering gear to see if its original to my car,will snap some photos
jonnyrose Well-Known Member Joined Aug 30, 2017 Messages 227 Reaction score 89 Location canada May 25, 2018 #10 so does this steering gear look stalk,plus does the weld near the idler arm look factory
