[FOR SALE] Small Lot of Holley Carburetor Parts
streetkit
Norhtern CA
Small Lot of Holley Carburetor Parts:
A) 4 Vacuum Secondary Pods
B) 12 long fuel bowl bolts
C) 3 secondary metering plates
D) 1 new power valve
E) 1 Model 4160 fuel inlet fitting
F) 1 Accelerator pump arm.
All are used except for the power valve which is new.
$30 shipped to your door anywhere in the USA
Located in CA
can you lay a scale or tape measure across the top of the 2 vacuum pods, the 2 on the left in the picture? please post a picture.
I can do that when I get home tonight, but they are just standard pods one off an 1850-2 and one off a 3310-3. Nothing particularly special.
thank you sir, unfortunately they are not the ones I am interested in. I just had to make sure.
