scott657
Collecting parts for an 8 inch swap. Only real problem I see is the shock mounts. The spring pads on the ford are 3 inces wide and the axle tubes are about 2-1/2 od thought about speedway universal mounts and modify to my application or custom make hhem
Photos later im at work
