[FOR SALE] B-1 BA 340
kingvern
Clarksville, Michigan
$5,800.
This engine is brand new only ran on test stand. However it has been sitting for 20yrs.
I have the paper work for the rebuild. It is a 1971 block, with eagle H beam rods, forged crank, Brodix B-1-BA heads, ARP HEAD STUDS, Main studs. Crane gold 1.5 roller rockers, Crane push rods, comp cam. # 20244-4 550 lift 306 duration. TRW FORGED PISTONS. # 2316F .030 with these heads it should be 11.5-1 compression. I am sure that i missed something. Engine should be taken apart and cleaned. Still worth every penny that I’m asking. If you have any questions please message me.
Looks like a nice set up. Unfortunately before I would even think about buying it I would have to see inside. As is you need to pull the heads and oil pan and show what it looks like.
Exactly, all the cylinders could be rusty dusty and that makes the pistons/rings for sale and a new oversize set necessary..
72 Darts didn't come with 340’s. 318 was biggest offering
So if it indeed came out of that, it wasn't born with it
well. it ain't mine. 71 Demon, born in april. I think I need a real early 70 or late 70 block.
