90 deg oil filter adapter...
Cuda416
South, TX
What were the vehicles that had them from the factory? Tryin' to edumicate myself before the junkyard crawl....
Looking for an adapter, and they're not cheap!
Check out a ford parts website. The Windsor 90* adapter will fit a SBM and much cheaper. Same thread size and o-ring/gasket size.
If you can do without one, your engine will not complain. I put a short filter on my 367 with TTIs; lotsa room. Oil changes are a lil tricky but I can still do it in my driveway, with a bit of ingenuity..
My 68 340 car and 68 318 car had them. No real help though. Probably not a bunch of those in the junkyard.
If you don't want to wander junkyards looking for this part, I have the adapter, and the bolt. $60, including shipping. I think Mancini's has the gasket.
