mopowers
Anyone run 205/75/15s on the front of their A-body? How close do they come to rubbing on the front wheel arch? Can you share a picture?
unsure of the translation but I run 26.7.50's on 15's
Thanks! You don't happen to have a side picture of it do you? How close to the front fender lip is it?
That's a 27.1" tall tire.
I personally don't consider anything taller than 26" for the front. It's not totally black and white, the wider the tire the less height you can get away with because of the backspace and turning requirements. And obviously ride height plays a big part. But with the typical backspace you find on 15" wheels and a stockish ride height I wouldn't expect those to fit without modifying the lower front corner of the wheel opening.
From the side with the wheels straight ahead isn't usually the tightest clearance to the fender. Typically the tightest clearance is with the wheels turned slightly, the innermost edge of the tire ends up farther forward than with the wheels straight ahead because of the width of the tire. Again, it depends on how wide the tire is and what the backspace is. The further in the wheel sits the better that clearance usually is. Alignment plays a part too, the caster and camber will effect how much the wheels tips on turning which also changes the clearance. Folks have even found less clearance when turning while backing up, the big rubber strut rod bushings (if you have stock style strut rods and bushings) let the LCA move a little bit forward under those conditions, reducing clearance.
The tallest front I've put on are 215/65R15 which are almost exactly 26 inches diameter. With 4.25 inch backspace 15X7's. There was a slight tick of rubbing.
I've used 205/65R15 with good success. (25.5" diameter)
I currently been using 215/60R15 (25.2" diameter) last few times.
With my front suspension pretty much aftermarket (only the lower control arms are stock somewhat but reinforced) I've been thinking of switching to 17's.
Yes, this is on my 74 duster.Thanks! I'm assuming that was on your 74 Duster?
