Hurst Quarter stick install questions
niceolddart
S.E. Pa.
Has anyone installed a Hurst Quarter Stick in a 1st gen. V8 Dakota? I bought a used one cheap, with the cable, cover & all but the bracket & lever to hook it to the transmission (518/46RH) I am going to get the bracket & shift lever new from Hurst, but I have no adjustment instructions. Any help would be great. Shifter works great by the way. Thanks
I have one in my Duster with an A-500 trans. I adjuster the cable so the trans and shifter are both in neutral at the same time. The rest of the positions will then line up. OD and LU are controlled separately from the shifter as you likely know.
Cley
Thanks for the info Clay. I like the hood scoop on the Duster. I want to bolt one on my Dakota (a Dart sport one) some day, but they are kind of pricy even for a slightly damaged one. I'll find one eventually & make if a functional piece.
