troop
Installing new PST 1.03 torsion bars on my 72 duster. The old slant six bars came out with no problems. Right side went in perfectly and I was able to get the clip in. The driver side will not seat completely in order to get the clip in the back. I thought maybe I had too much grease inside the LCA, but I removed it and wiped a lot of the grease out and it still won’t seat. The LCA Looks properly positioned. I’m not sure what the problem is. I thought I read somewhere that someone had a torsion bar that was slightly longer than the original and they had to grind down the end. Any help would be greatly appreciated thank you
