convx4
Found a tach and sending unit with these part numbers:
Sending unit 2496162 Tach 2496979
Very expensive cuda 273 tach
Looks like it I am not really versed on them. Hey @ZMan67S
Both applications have a very similar look and may be the same exact tach assembly. The electronic box is the sending unit for the tach. If this is an "A" body tach it is a '64-'65 only. '66's used an integrated tach inside the guage cluster.
Would you like to sell the tach and unit?
