Headers for 73 Duster with 451
The Hedman’s will not fit with a 440 using Schumacher kit with 68-72 k-member. This was on my 68 dart with auto trans. I was able to get the passenger side on with minimal torsion bar interference but drivers side was a no go. This was with manual steering and the steering shaft collar shortened to fire wall. The torsion bars were also 6 cylinder bars. Hope this helps
Dartgame
Thanks for the real deal info.
:thumbsup:
Hi
I would like to know what under chassy headers will fit a 73 duster with a 451 B-engine with TFS heads? I really don't want to cut the car at all to put headers the car is a real clean original car.The car has no P/S and No P/B to worry about. It is getting the spool type mounts as well. I would like at least 1 7/8 and if can put in 2" would be better. Engine right now is in the 650HP range and is going to be driven both on track and street. I keep reading about TTI's some say they fit others say they don't, not sure if Hookers work or Dougs work either. ?? Any B Headers work?
What choices do I have? I seen Schumacher but not keen on Tri Y
Thank you very much
I have a set of hookers B engine A body fender wells. But there to exspensive to ship. I want 300.
