I grounded coil positive to block?
I'm with Kim. I can't remember how many parts cars i had back in the 80's, 90's with the burned hole on the bulkhead plastic at the fusible link.
I don't get this. If the OP is running an MSD CDI box, I'm not sure how grounding the coil would cause all this mess. The coil+ on an MSD 6 or other CD box is not connected into the normal power feed like it is originally.
In any case you need to troubleshoot each problem "on it's own" and do some actual troubleshooting, not guess
The fuse link is not open if you have power "in the car" such as dome, headlights.
So start with the feeds into the engine bay. There are only 3 to worry about
1....Ignition run, or IGN1 comes from the key "run" contact, and feeds some things in the car such as cluster power, and goes through the bulkhead originally to the ballast. This should now be connected to your MSD "small red." So with the key in run you should have power there This is often dark blue, refer to your shop manual, not all years
2....Ignition "bypass" or IGN2 bypasses the ignition resistor and is the only ignition power during cranking. With the key twisted to "start" the MSD "small red" should also be hot. IGN1, above, goes dead in this function
3...The normally yellow "start" wire. This comes off the key, is hot ONLY in "start" and goes through the bulkhead to one of the two small flag connectors on the starter relay. Check with a light or meter, this should be "hot" with the key held in "start."
From there, power goes through the starter relay coil, (magnet) and "comes out" on the remaining small flag connector. From there, it is grounded in park or neutral by the neutral safety switch, or if stick car, is grounded by the clutch safety switch.
You need a service manual and or wiring diagram if you don't have one. I've posted this a xillion times. Go to MyMopar and download them for free.
THANKS. It appears to be a major power problem
First, with all wiring connected "as normal", measure voltage with your meter to the large alternator (black) output wire at the alternator stud. That should be "same as battery" at all times. If you have voltage there, pull out the headlight switch and recheck.
Next, wiggle the bulkhead connectors with the light switch "on" and look for any activity in the headlights. Also wiggle the fuse link area. Take the terminal/ connector part in that fuse link area, check it for continuity. That really at this point is the most likely suspect
If you have not done so, probe into the bulkhead connector area where the fuse link connects, and see if you show voltage there. If so,..........
OK next thing I'd do is pull the bulkhead connector sections apart and inspect the terminals. This is a known problem in these girls.
Read this article for information. Don't worry about the bypass part of the article, but it explains part of the problems with the bulkhead connector and ammeter circuit That article also has a simplified diagram which shows a good idea of the primary power distribution
Catalog
The diagram from this article:
Follow along. There are minor differences over the years. From the battery, power gets to the big stud on the starter relay. This is not only a junction point, that stud is also one contact of the starter relay. From there, the fuse link goes through the bulkhead connector, on the RED ammeter wire to the AMMETER. Through the ammeter, and out on the big BLACK wire. A few inches later you get to the WELDED SPLICE. From there power branches off and feeds the IGNITION SWITCH, the FUSE PANEL hot bus, and HEADLIGHTS power. It also feeds back out through the bulkhead connector (BLACK) to the alternator
So WHAT could have failed?
In no particular order, the fuse link, connections at the bulkhead connector (RED), connections at the ammeter, and the welded splice itself.
Well I finally had time to get back at it. I went through the steps in your earlier post and found I do have power with the switch on out the yellow wire on the relay. Went back as I have already removed and bypass the fusible link pull the bulkhead connector apart little corroded but seem to be get in good shape. Cleaned it up and put it back together.I do have power on the other side of it as well as out the fuses.I guess my next step is to pull the dashboard and check the meter gauge?
What was the voltage at the large black wire attached to the stud?
What was it after you turned on the headlights?
Do not turn the key on or to start for those initial tests.
"I have already removed and bypass the fusible link"
That eliminated the only little bit of protection against battery shorting and destroying something.
Fusible Links in Charging Systems with Ammeter
"I do have power on the other side of it as well as out the fuses.I guess my next step is to pull the dashboard and check the meter gauge?"
We don't know if you have power on the inside. You have potential power. The way to test for whether there is power was by turning on the headlights. With the markers, dash and headlights on there will be 10-15 amps flowing thorugh the ammeter from the battery. You will see it on the ammeter. You will see a voltage on at the alternator stud that may be different than the votlage on the battery positive terminal. Then we'll have a better idea if there is an issue with power before the key switch.
It does have the MSD box and distributor could I have done something to the box?
Yes its possible.
With an MSD wired in, power to the coil will come from the MSD box. The MSD box gets its power in from wherever the heavy red cable is connected.
OK where do you and don't you have power? Do the headlights work? Do you have power at the alternator big black wire with the light switch on? (This is to put load on the circuit)
Here's the thing to keep in mind............when you are dealing with poor connections especially in large wiring, a connection is not always "always bad" or "always good". Your meter or test light does not draw much current. There can be enough power in a circuit to show on the meter, say, at the fuse panel. But when you pull the light switch, maybe it goes out. This of course shows the load now "kills" the power through the bad connection.
This could easily still be in the bulkhead. You basically have THREE connections at any one bulkead terminal.........1, the connection between the engine bay side wire and the terminal, 2, the connection between the two terminals themselves, and 3, the connection between the interior side wire and the terminal.
I have to ask... ( my sister had my dad leave work to help her out one day because of this) is the trans in Park or Neutral? it will not crank if not.
have you done anything to the trans linkage before this happened?
DO YOU HAVE A WIRING DIAGRAM? download one at mymopar.com OR beter yet buy one from classiccarwiring.com. when you started posting I pulled the trigger and bought one. I have used it several times in the past week alone just for your issue.
I don't remember but I thought you said you did not have cranking of the engine? If you have power at the yellow wire ("I" terminal) ON the starter relay you should be able to crank it UNLESS neutral safety switch (NSS) is the issue. before you pull the dash apart I would investigate that.
one of the wires on the starter relay goes to the NSS then to ground (small brown wire in 67 dart, other years might be different? key interlock? etc.)
"G" is the terminal that should go to the NSS. with trans in park or if manual, in neutral, check voltage from battery + to terminal "G" WITH all the wiring in the car put back on. you should get 12 V. If you don't start looking into the NSS or the wires along the way.
Do your headlights work now?
^^Just for electrical correctness, the "G" and "I" terminals can have the wires reverse in some years and they work fine, electrically. For some years, the connectors are molded "keyed" so that they only go on one way. But electrically does not matter.
Well by George took quite some time chasing it but I got it! Pull the bulkhead connector apart again cleaned it up really well,Replace the starter relay and the neutral safety switch in the transmission guess that short knocked out quite a bit.I still think the fusible link was part of the issue as well Probably the last to go. Runs excellent. Thank you for taking the time to explain it to me I appreciate it! Out of all of this I do have two questions
Should I install a new fuse or fusible link?
Should I illuminate the ballast resistor in electronics box?
In One of the pictures I posted earlier in this thread showed the MSD small red wire going to a cluster of wires does this seem right? Thank you
You may not be done. You can buy replacement terminals for the connectors, known loosely as "Parckard 56" You need to be sure and get the right flavor
Once you think you get everything together and correct, you need to run some voltage drop tests to be sure the VR is not overcharging the battery. What I mean is, that voltage drop TO the VR will cause the VR to boost voltage and cause a battery over-voltage problem
To check this, with everything connected, having been running, warmed, and with battery "up" to normal, Run two tests
1...With key in "run" stab one meter probe into the battery POS post, and connect the other as close as you can get to the VR ignition terminal. This is likely where the ballast has been bypassed. You should read a VERY low value and the lower the better. Do not disconnect anything to read this. You want a load on the circuit. Anything more than say, .3V you need to find out why
2...Ground circuit........With engine runnning to simulate low-to medium cruise RPM, do this first with all accessories off, and again, with heater, lights, etc, on. Stab one probe into the battery NEG post, and the other into the VR mounting flange. As before, you are hoping for a very low reading, zero would be perfect
The MAD article I mentioned earlier deals with these issues.
Where troubles fall in the original wiring, in no particular order:
Bulkead connector, as you are finding out.
Problems with damage and looseness and or corrosion at the ammeter, and bad wire end terminals at the ammeter
Broken welded splice in the black ammeter circuit. This is rare but has happened. I found my first failed one in about 1971 in a friend's 69 RR in the parking lot of his apartment. had the dash and harness all over the front seat. He thought I was nuts, and I did too for awhile. Over the years, I've been privy to maybe 8-12 of these failures
Bad connections and failure in the fuse link
On newer cars, there is a white colored engine harness connector that fails
All this is made worse by great big alternator or large power hogging accessories, like stereos and electric pumps and fans
That red wire going into a bundle of wires you describe is the switched power to the MSD. If I'm following correctly.
And yes as was mentioned earlier I would reinstall that fusible link. Its the safety net, it burns so the rest won't.
