V8 Sam
Dodge is running for the first time in years.
Infact it's running so well it no longer turns off on the key
Have to smother carb intake in order to kill it.
Any ideas? Before I start looking into it. I'm thinking maybe the ignition switch.
When you connect a battery terminal the 'oil' light comes on on the dash as if the ignition is switched to on. But without a key in the ignition.
Then flick key to on position and oil light flickers a little but stays on. Then flick to start and it fires up. Switch it back off and take key out does nothing.
On a side note wipers and indicators no longer work either, don't know if related or separate. Main lights work fine.
