76 dart coming soon to be parted out.
Bronze Barracuda
Vancouver
I will be picking up a 76 dart June 19th.
I will be parting it out. I know I will be keeping the front brakes, booster and master cylinder. Plus the rear diff. I bought it sight unseen. But it seems to have some stuff ( taillights, glass, body parts, trim, etc. I will post more pictures and a full description of what is salvageable once I get it. .
Need the engine wiring harness from the firewall plug-in.
This is the under hood engine compartment harness.
But may need dash harness also, I'll check it.
Need the engine wiring harness from the firewall plug in.
Ok once I get it I will be taking a couple days and tearing it down. Will get back to you and anyone else shortly thereafter. The dash is intact so the harness hopefully is in good condition
I could use good condition rear armrests, with or without the ashtrays, if so equipped. Looking for light color armrests. I am local in White Rock.
You have a '76?
When you have a chance, post pics of the wire harness, esp the fusible links and shunt.
Every now and then some one has a problem with a '76 and be nice to have some good pics.
When you pick it up, I’d be interested in the dash pad if it’s in good shape. Are you in the Vancouver above or below the 49th parallel?
I will be posting an ad in the "Mopar For Sale Ad's" section under Mopar Parts Cars on June 19th.
With pictures and a more detailed parts list.
I have been informed that I/we should not list cars before we have them.
I have already payed for it, I just can't get the time to go pick it up till the 19th.
I am damn happy with this find though, great for front brake conversion and I can also use the rear end out of it. Although I do have a spare 8.75 with a 741 carrier. But I believe the 8.25 should have the 5 X 4.5 BBP My 8.75 has the SBP.
Curious as to how tuff a 8.25 is compared to the 741/8.75?
I guess I can talk about the car in general.
Ces't la vie
PS I do not know what a Dart Lite Model is.
Googling that right now...
