Yep,that's what I think to,talked him out of the iron one today,thanks for the infoI would recommend an aluminum Edelbrock RPM intake manifold if you don't want it to leak. As stated above, cast iron and aluminum have very different thermal expansion coefficients. 65'
Does this mean that aluminum manifolds won't work on iron heads?
Yeah, you can't do it...better not put aluminum heads on an iron block either...Does this mean that aluminum manifolds won't work on iron heads?
