Which Alternator Brackets?
RustyRatRod
I was born on a Monday. Not last Monday.
Georgia
64 Valiant from slant six to B engine. Which factory alternator bracket set will work? Stock 906 iron heads, stock block. Alternator on the passenger's side now and that's where I want it to stay. It doesn't have to be 64 brackets, just so it mounts on the passenger's side. Alternator only is what I am running now and will run. Maybe A/C added the distant future. Thanks.
I probably have enough to get that done for you. May have to wait till you get the heads and water pump housing on to pick out the right brackets.
The one DAVESCUDA show is correct if you have a 67-72 water pump housing with a drivers side outlet . It is also good for the 72-78 with passanger side outlet . Either way it is for anon-A/C motor . IMO , putting A/C with a "B" engine in a 63-66 A-body is just about impossible .
I can do that. "Hopefully" it may not be much longer.
I am will be using the 440 Source pump housing with the passenger's side inlet.
Good. Then when this is "all said and done" jaws will drop even harder. I have people telling me it caint be done like I am doing it. That just fuels the fire. lol
ya daves got it Thats what i got p#127-1007 alt .bracket 28.95 and p#109-1511 bolt kit 18.95 but AC ????? I dont think so
