rustycowll69
I don't know how I missed this thread before. I have kind of a soft spot for the Ramchargers. I had a loaded, all-black 440 75 SE(I think), which I converted over to '78 exterior trim, and repainted mostly black over red garnet pearl metallic sides(between the trim). It was quite striking. I frequently got compliments from complete strangers on the paint.
Something I did was to drill holes in the interior side of the roof shell and sprayed foam insulation in between the sheet metal to combat the sweating. It also reduced the noise level inside, too. Of course, I used black plastic plugs to cover the holes, and it didn't look bad at all.
