[FOR SALE] One 15 x 8 Cragar SS wheel sbp
8formulas
Connecticut
I have one (1) 15 x 8 deep dish chrome Cragar SS wheel with 2.75 back spacing. This is for a small bolt pattern car (5 on 4 inch bolt circle). This wheel is not bent and rolls true. The chrome is in good condition. Sorry, I only have one wheel. $60.00 plus the ride from Shelton, CT 06484. Thank you.
Hi, are these wide rims? I'm looking for wide rims for my 75 dodge dart sport. The local tire shop near me said 15x8 , Bolt Circle 5x4.00 , offset -06, Backspacing 4.26, Hub bore 71.76 is what will fit mine.
75 dart is 4 1/2 bolt circle , not 4 bolt circle , 72 dart was the last year of 4 bc unless someone put it in your car .
It's only 1 wheel. What are you going to do for the other side?
Mine has a 4 inch bolt pattern (SBP) so as long as you have a 4 inch bolt pattern too, it will fit. Mike
I don't know much about the sizes i took the car over to the tire shop so they could measure it for me & they said 5x4.00 Bolt circle. & then i saw some reviews were some guys would say they have 4x5. So would 4x5.00 & 5x4.00 be the same ? Sorry i'm terrible with try'n to figure out these measurements.
A 1975 Dart Sport would have the 5 bolt 4 1/2" bolt circle (not 5 on 4") unless someone transplanted a rear end or front brake hubs from a 1972 or earlier car.
Post a close-up picture of a wheel on the car now and many of us can pretty much tell just by looking.
5 on 4" is what is refereed to as Small Bolt Pattern or SBP.
Hope that helps.
Hope that helps.
Yes, thank so much. The wheels on the rear are pretty skinny. I also have a slant 6 did they only come with a 7 1/4 differential? I'm just afraid to order online cause i did that last year for 1 SS cragar rim & it was the wrong size & it cost me $80.00 to ship it back to the company. I wanna buy the widest rim i can get on there without having to move the springs yet. These A bodys look so great with fat tires on the back. I tried to upload some pic's but it says the image is to big.
If I was you I would measure the bolt pattern myself.
That sure looks like 5 on 4" to me. I included a pic of my wheel with a tape to show it's the same pattern.
My wheel is 2.75 back spacing so I believe you'd have plenty of clearance. What size tires will you go with? 275 60 15?
In my opinion 275 60 15 would be the size that would look best on 15 x 8 wheel. I have that combo on my 74 Firebird and it looks great. But that's my opinion. You also have to be concerned with height. You don't want rubbing issues on the qtr panel wheel lips.
That's true. I do have a lot of room on this dart which is good & air shocks. I was looking at some photos of that size tire & i would like a little bit wider. Would a bigger size fit on that rim? I mean just a little bit wider.
I'm not really sure what other size tire is out there that can be used on a 15 x 8 wheel.
Perhaps Hoosier has a 28" tall tire with a 10.5" tread. You'll need to look around. Check Mickey Thompson too.
