[FOR SALE] One 15 x 8 Cragar SS wheel sbp
I'm just checking out this video on youtube the 275 60 15 tires on this 70 Nova does look pretty good. I'd be happy with that for a few years until i can afford to mini tub my car. Do you know what the shipping would cost to AZ?
Looks like 4" bolt pattern for sure.
If you go with a tire wider than 8" you'll want a backspace of 4" or less.
It might be 4.25" from the drum face to the spring but the tire sidewall bulges out passed the wheel bead edge.
Now the you have the wheel off... measure from the drum face to the leaf spring.
This 'deep dish' wheel would work fine but finding a match will be a needle in a haystack.
My backspace is 4.26
Would it be hard to find the same rim?
The first one i've been watching for a while on Summit , it used to be cheaper than they raised their prices. Is the first cragar rim the same as the one he's selling here? Cause that is the one i was gonna buy to match the one on sale here.
It is Not a match.
Wow, this sale thread has turned into a chat room. The prospective buyer has small bolt on his 75 it appears. It also appears that you can't buy a new Cragar SS with that backspace.
My wheel doesn't appear to be a good fit for you. Plus, the shipping from CT to AZ is very expensive. Save your money, do your homework and buy a set of matching wheels for your car. Good luck. Mike
