I have a 400 block and want to make a 440 crank stroker,and I'm leaning towards the 470 with the offset ground rod journals vs a 451.
Because this is a street combo and I want it to last as long as possible before rebuilding, I've been advised to try and achieve a rod ratio of 1.8:1 or close to, and to use as tall of piston as possible.
What off the shelf rod and piston choices do I have?
