Rims?
bolt pattern?
make arrangements to try them on your car. Drive car there pull one wheel each side. whatever you have to do to be sure they fit.
Car is in pieces right now. So driving and test fitting is not gonna happen.. I guess the worst thing is if they don't fit I can resell them.
From 14" rims might not clear your calipers depending on what you used to convert to BBP. With stock stuff the front track go wider by about .375" per side. We need more info on how and what you used to convert to BBP and the actual size and offset of these rims.
you got some homework to do or like you said, buy them and if they don't fit, resell them
I went with a Jeep Cherokee disk setup on my 8.25 rear end.
If the size is right, you could shine them up with some Mothers Polish
you can use spacers in the back to adjust them if needed
