[FOR SALE] 410 LA Stroker
gumper
Butte, MT
Rating - 0%
0   0   0
Nearly new Chrysler 410 stroker engine. Scat forged rotating assembly. Crank is ground 10/10, cylinders .040 over, Icon pistons 12.7:1 compression, 6.123” I-beam Scat 60 rods. Ported Edelbrock heads that flow 280/240 @ .600 lift. Comp steel roller rockers. Hughes solid cam STL5054AS-8 .588/.600 lift, 250/254 duration with their lightweight lifters and Smith Bros pushrods. Weiand single plane. Has been running a Ron’s Flying Toilet on methanol in a 3200# Duster. 25 1/8 mile passes, ran a best of 7.11 @ 95.6 mph at a DA of 7300’. Can come with the Hooker headers for an A-body. Still in the car, so you can hear it run. Can come ready to run with the Mallory ignition setup (distributor, digital box and coil) for $6000. Engine with toilet injection for $5500. Manifold to pan for $4000. Going to switch to a late model engine, so this one is no longer needed.
Damn great deal..
If I hadn't done my engine for this year, I'd have bought this on the spot, minus intake and toilet.
Great deal for some lucky buggar...
I'm telling you some guy is going to be lucky to get this build, for that money.
MAPS
