[WANTED] column shaft nut
1/2'' fine thread that takes a 3/4'' socket. Grade 5 or 8 at the local hardware store.
Also a 1/2'' lugnut inverted works in a pinch but not sure if the factory horn center will fit.
Worked on my Grant aftermarket steering wheel.
