Is there a difference between 360 truck motor mount and 360 car motor mount
Austen G Ornduff
Austen from poor mans speedshop youtube channel
Terre Haute Indiana
Hi I'm getting ready to drop a magnum 360 in to my 1973 dodge dart sport my car was a originally a slant 6 car three speed manual I have swapped the original k frame for a new v8 k frame I'm getting ready to drop my magnum 360 in with a 727 is the truck motor mount the same as a car and if they are not were can I buy a set of car motor mount
What year V8 K frame did you swap into it? '67-'72 takes a different style mount than a '73-'76 K frame.
Are you talking about the ears on the block or the actual mounts?
Was told by the guy I bought it from it's for a 1973 dodge dart sport
Also the drivers side mount is different between 273/318 and 340/360. You can use a 273/318 mount but you'll need some spacers or washers.
Looks like someone did a kframe swap. 73 has the spool mounts like moparmarks. I read somewhere that the truck magnums have mid engine ears on the blocks but idk tho. Do you have the engine already?
I just read in your op that you swapped the kframe haha my apology I should learn to read!
Yes Magnum motors have both the Magnum mount bosses and the LA mount ears.
I have a 5.9 Magnum in my 72 on the 73 frame.
I remember a thread that says you can use a truck mount on the driver's side to put a small block in a slant K frame.
I heard the same many years ago but never actually tried it myself.
I also remember seeing that and I've been searching for it but can't dig it up.
Thanks everyone for the information it really helped I'll be covering the build on my dart sport on my YouTube channel poor man's speedshop after I get my 1990 ss454 done if any of u would like to check out my channel thanks so much
