Does any one know if you need anything else but this box to retard (nitrous) the timing after its installed?
Thanks.
MSD 8676 Retard Module Selector, 0°-11°
Thanks.
Thanks.
@Jpar. I know he bought some stuff to retard like you want to, but I don’t remember what it was.
He can tell you.
Why do you constantly have to be an Internet hero...That's because he are one!!!!!
I use a similar set up but maybe a little bit more advanced I would say. And a little bit more expensive LOL...I have is a start / retard... It has that same feature on it but it also has I start feature as well. If I'm not mistaken that one you can just change your timing on the Fly... The one I have you can do two different features. The first one is the retard for starting the car. It's mostly used for people with a locked out distributor meaning a drag race application where the distributor is set let's say at all in at 35 degrees all of the time meaning it never moved at all from that. That makes it really hard to start the car so this feature lets you retard the timing x amount at startup and once the car starts reaching some RPM the timing swings back to the 35 degrees. The other feature is a signaled timing retard meaning when you give it a low voltage signal as in an activation button it will retard the timing for that momentary amount of time you're giving it a signal. Like what I use it for nitrous. Nitrous is much more efficient so it doesn't need as much timing. The basic rule of thumb is to take two degrees of timing out for every 50 horsepower of nitrous. So in my case where I have two 50 horsepower plates on my car adding up to 100 horsepower I have my timing retard set for 4 degrees. So as I hit my nitrous button to activate the nitrous and also sends a signal to the timing retard and retards the timing four degrees at that moment.This will show all of you nice folk how dumb I really am.
4 posts after my initial Q. and I yet to understand anything.
Please in layman terms...
Will I need any chips for this machine or are they already in this box ?
Seeing it has a dial already stationed with numerical positions on the face of the box for you to just go to the actual retarding you need (or, in my case, are, lol)
Or are the numbers just there to show you this is were you need to position the dial to get the timing you want, now that you have the chips (installed) in their designated area. With the advantage of having a multitude of degrees you can use... Because/With these chips/modules.
Compared to the other boxes I've seen that seem to be digital and have 2-3 degrees positions you can retard the timing by just turning the dials on the back of those machines?
Thanks waaaaaay in advance.
