[FOR SALE] Knobs, Bezels and Miscellaneous Knobs & Bezels
65 Dartman
1 of None 65 Dart Sedan Delivery
Strasburg, VA
I have accumulated many mostly early A Dart and Valiant wiper knobs, radio knobs & bezels that i can readily identify with a smattering of miscellaneous knobs and bezels I might be able to identify. Interested in closeups or other info, just ask either on this thread or by PM. Prices vary by item so I’ll start at $10 per item shipped from 22657. The lower the price per item with more you buy. I will consider an offer for everything.
i will take the 3 68 style wiper knobs with smooth face and the reverse indicator if that is what it is
I see that I cut part of that first picture off and have changed it to an updated one I think you are referring to the 4 on the 3rd row down from the light knobs. The 4 are I believe radio knobs - which is the one on the left. The one on the right Should be the only Valiant wiper knob I have which Has the wiper shaft set screw
the warning light is for Reverse
I was asked if I could identify some of the knobs. Top center is a Signet door emblem for a 65 (may be applicable to other early year Valiants. To the right is a late 60’s fender top turn signal -no lens. To the left is a hazard switch from a C Body year unknown. Below it are 3 headlight knobs for a 65 Valiant or Barracuda. Then there is a wiper knob same application. 3 wiper knob bezels For a 66 Barracuda and might fit same year Valiant. The one on the left has been rechromed as per original for the Barracuda. Then 1 headlight knob bezel same application. To the bittom left are a couple of bezels for the wiper and brake release for a 65 Coronet.
below the top right fender turn signal are 4 wiper knobs fir a 65 Dart, then 3 radio knobs same application. The lighter is for a 65 Dart. I “think” the 3 bezels to the left of the light is for a Valiant but not sure. The 3 knobs bellw them are radio knobs unsure of the year. i “think” the 4 bezels to the right are for a 65 Dart radio. Everything else, I really don’t a clue. Hope this helps.
I'll will take the convertible top pieces below the turn signal, if that is what they are?
If you mean the 2 shaped the same below the Signet door emblem and Reverse light bezel (which is sold), yes, they are for either an Early A (65 Dart) or a 71 Challenger.
yes, can you post a picture of the two convertible top transition pieces
Actually I’ve found a couple more lighters knobs and will take some pics if everything this afternoon.
Okay thanks. Curious what it looks like compared to what I got now. Probably will buy it if it seems right.
Picture of the '65 Lighter up close?
I sold a set of 65 knobs so the one in the pic is gone (it was basically driver quality; however, i found 2 more. The one on the left is similar in condition to the one I sold; the one on the right could almost be termed NOS. It screws into the element (have several elements).
Left used; right near NOS
I guess I will take it. Not that I smoke or anything but my car seems to have one that is not correct. (If you want to just request what you want for it through paypal that works.)
I’ll do better than that - install a decent looking element to the nice knob (couldn’t get the knob off the other element).
